Hey all!
I upgraded my HTPC from an aging AthlonXP-m 2600+ to an Opteron 165 so that I could record 2 SD + 2 HD at the same time. I have a few parts left to get, but am just about ready to go.
So, when I got the 165 the first thing I did was work through overclocking it. I don't have really good memory so I think that's holding me back.
Anyways - After much work and experimentation I have the 165 @ 2440mhz 1.375v. 270mhz FSB HTT 4X (1080mhz).
It's been burning all weekend with two instances of Prime. Currently, Core 0 is at 55 degrees and Core 1 is at 65 at full tilt. Being my first Opteron and my first A64 build altogether I'm just not sure what kind of temps I should be expecting.
Currently I have the stock Opteron cooler, the one with four heatpipes. I was looking at the Zalman 9500 and the Scythe Ninja. The case I am getting in an Antec with a 120mm fan on the back. I was a fan of the Zalman but the price is putting me off. I was looking at running the Ninja completely passive and relying on the 120mm fan on the Antec to pull the heat off.
So my questions are - are these temps out of whack for a Opty 165 overclocked this way and if you would recommend an aftermarket cooler does anyone have any experience with using the Ninja in the way I have described? I've been doing searches on the net all weekend and still have no clue as to what the best thing would be to do. Looking to get some practical advice.
Thanks!
Thanks!
