Do I need a sound card for USB Speakers?
Mister Walrus
23
Hi all,
I have the Altex Lansing FX5051 5.1 USB Speakers, which I use currently for my laptop. But I'm building a new desktop computer, and wondering if I should buy a soundcard other than the onboard audio so that computer games will recognize the 5.1 system. Will it make any difference in the audio I perceive, or will the sound bypass the discrete soundcard altogether? Thanks for your advice!
Aluvus
2,913
USB speakers should be acting as your sound card, should not matter if there is a sound card in the system at all.
octopus41092
1,840
Most sound cards don't have a USB slot on it so you probably won't be needing a sound card. Also USB speakers probably means theres a sound card built into it or something like that.
LOUISSSSS
8,770
54
YES, usb speakers will bypass any sound device u have in your system and take the sound directly from the operating system. (someone can test this by disabling their onboard sound/dedicated sound + remove any onboard/dedicated sound drivers) Just use the USB speakers without those devices.
