- Jan 3, 2001
- 12,650
- 207
- 106
I've pretty much determined that I've got a bad motherboard (corrupted bios?) or a bad CPU. A buddy has just sent me his known good cpu. So I want to now try his CPU and see it I can get a bootup.
Problem: I have since cannibalized that computer and used its parts to build another computer. I don't have a case readily available right now but I do have a Power Supply that is known good.
Question: My plan is to place the "known good" Power Supply, Motherboard on top of a card table. Plug in a floppy drive, video card, CPU/fan, and memory. Place a bootable floppy in the FD and try to start it up. If it can make it to the floppy, I believe I will have determined that I had a bad CPU. If I can't get the floppy to startup then it will definitely look like a motherboard problem. What's wrong with this plan....if anything?
BTW, the symptoms on hitting the start button: CPU Fan, Power Supply Fan spin up to speed. Nothing else happens. No hit on the Hard Drive or the Floppy or the CD-Rom. All connections have been checked and double-checked. I'm suspicious that a virus may have corrupted the BIOS. If not that then something else had just quit on the motherboard.
Question: Do I need to have the motherboard grounded to anything to try this test?
