Do I need a 2nd battery for my future laptop (T42)?
eLiu
6,407
Edit: Answered most of my questions when I found the IBM "TABOOK" on their FTP.
So the question at hand:
I plan on buying a IBM T42, most likely the 2379DXU. (1.7ghz, 512mb, 15" SXGA+ screen, 60gb 7200rpm, 9600, bg wireless, 6-cell battery, 3yr warranty)
To my understanding, it's better to run a Li-on battery down to like 20-30% before recharging (so as to not waste charge cycles). If that's the case, would it be better to have 2 batteries? So I can run one down to 20-30%, then swap it out and charge it in the night.
In addition to that, I'm concerned that the 4ish hour battery life of the 6-cell will be a little short--I'll be using this thing in college where I'll be out and about all day long in class/labs/library/etc. Would the 6-cell be enough? I mean, I can't upgrade to a 9-cell, so the only other option is to buy a 9-cell from Newegg--it's $99, even cheaper than a 2nd 6-cell from IBM.
Thanks!
-Eric
Edit: Is now a good time to buy? Will prices fall if I wait until late July or so? (I start school at the end of August.) I have a shareholder discount, but I heard IBM will have some "back to school" discounts that stack on top of the shareholder discount--will the savings be worth the wait?
TBP
919
If you play the power saving right, a battery can last you a whole day. Most time it runs at <500 mHz clock speed.
As far as the price, check your school and see if there is an education discount with IBM.
eriqesque
704
Thanks!
-Eric
Who said you can't upgrade to the 9 cell battery?
If you call and place the order the sales rep can do better at adding things than you can on the web.
eLiu
6,407
Thanks!
-Eric
Really? On Thinkpads.com, there was someone that tried that twice and the sales reps told him know both times. But I'll give it a try when I buy. If I order by phone, I can still apply the stockholder discount right?
TBP, My school doesn't have a contract with IBM--theirs is with Dell (I can get a 2001FP for $809 with that deal...not bad). The model I was thinking of purchasing is $2,276.10 after the stockholder discount--10-15% (regularly 2,529.00). And with the battery, IBM reports 4.4 hrs with that model &amp; the 6-cell...seems kind of short esp b/c I'll have wireless enabled &amp; the screen not at 0 brightness.
Though, do you guys think I should buy now? Or sit tight and wait for the IBM summer sale deals?
-Eric
