Do I have PSU problems?
Todd33
7,842
My BQE3700 has a 350W PSU, but lately I've seen some random weird stuff. The only things that have changed are the OC of the CPU and X800, both are independently stable during tests and have 3rd party coolers, the 7000 Al-cu for the CPU and the Arctic Cooler 4 for the X800, so I'm not convinced they are too hot.
- My system beeped and rebooted yesterday in Riddick.
- My USB hub does this weird disconnect/connect dance, making the OS play the USB sounds. It seems to do this mostly in games, full throttle so to speak.
Anyone think I should go to a 450W quality PSU just in case? Any <$100 recommendations?
I'll run prime95 for the CPU and ATItool for the X800, make sure they are stable.
P.S. I have two 7200 RPM HDs, two optical drives, one external firewire drive and the typical stuff, see my sig.
xsilver
470
dunno if "BQE3700" is a reliable brand -- but its probably not as good as a enermax etc. and most people here would suggest at least an enermax type 350w PSU to run your system
For under $100 you should be able to get a good enermax, ocz, pp&amp;c , or antec psu --- the first 2 probably being the most liked PSU's right now
if you're able to spend $100 -- u should be able to get a 400w+ one at least --- the most important thing being the 12v rail --- other considerations are up to you eg. nose; lights, cabling etc..
xsilver
470
Todd33
7,842
The Enermax for $77 looks like a good deal. I don't need a fast and furious-ish type PSU.
Anyone think a new PSU won't help?
