Do I have my IDE devices set up right? (HDD, Burner, CD-ROM)
DDDavey
195
Trying to get my this burner working in my moms computer. Let me start by saying I HATE working on this POS IBM case. What a PITA. She's running Win XP.
Running Nero version..well...it's frozen right now. Every time I try to copy a CD it freezes.
I have it setup like this:
IDE0 Primary: HDD ATA-66 cable
IDE1 Primary: CD-RW ATA-66 cable
IDE1 Slave: CD-ROM ATA-66 cable
I know that's not the optimal setup, I should have the burner by itself right? But if I have the CD-ROM and HDD on the same IDE channel will that drop the speed of the HDD? And in order to do that, I have to use a ATA-33 cable for now for the CD-RW because stupid one that IBM sent is a 1 device cable for the HDD and it's only like 8" long.
So. what's the best way to go about this?
Thanks,
Dave
jonmcc33
Banned
Feb 24, 2002
1,504
Make sure you have the Windows XP CD-RW patch and Nero version 5.5.6.4 (for Windows XP).
The configuration you have for your IDE channels is the optimal configuration.
kmike75
318
Is this a machine that you built or did she buy it somewhere? If the jumpers on the CD ROM are set to master and the Writer to slave you really shouldn't have a hardware problem. There shouldn't be a problem with the CD ROM and Writer sharing the same cable either unless it's a buffer underrun issue. Does your version of Nero support Windows XP? The "freezing" part sounds like a software issue more than anything else. Try another burning software or visit Nero or Microsoft to see if they have a patch.
DDDavey
195
Really? It said I couldn't encode 'on the fly' with the CDrom and CDrw on the same iDE channel..
I need to reboot before i can start Nero back up :(
jonmcc33
Banned
Feb 24, 2002
1,504
Don't ever record "on the fly". Since CD drives run at different speeds you are risking a chance of buffer underrun and making coasters.
Copy to the hard drive first, then back up to the CD-RW.
DDDavey
195
OK I rebooted. It's version 5.5.5.6 bundled is what it said. I'll go check the site...well...find it first and d/l the newest one.
kmike-it's a machine she bought from IBM. The CD-ROM was originally set to master, i changed it to slave and put the CD-RW to master. Should I have it the opposite way? jonmcc - thanks for the advice of on the fly..i'll keep that in mind. It keeps freezin up no matter what I do. I just d/l'd CDex and EAC, I'm gonna just try and burn a straight audio CD and see what happens....well, gotta go get the new version first
I don't know where to check for updates at MS.
Nero's website, latest version is 5.5.7.2...do I want that one?
dunkster
1,473
Your configuration is optimal for standard 2 IDE port system.
Installing a PCI IDE card (Promise, etc.) would provide 2 additional IDE ports, allowing up to 4 IDE devices as master on their own dedicated IDE port, and eliminate any need for master/slave configuration.
Hope this helps!
