Do I have enough power.
KK
15,903
4
I'm in the process of throwing together a new system. I bought a Antec 1030 case with a 300W power supply 2 weeks ago. In this setup, I'll have probably an P4S333 with a 1.6a processor, 5 80GB 7200RPM HDs (thanks BestBuy) with a promise SX6000 raid card, undecided on which cd burner, an ATI 7500 AIW, and 3 or 4 fans. Once I get it altogether and turn it on, what will happen if I don't have enough power?
Thanks
KK
fell8
533
It will probably be unstable, mysterous reboots, won't recognize hardware, errors, etc., or it may not work at all.
Heftier PSUs are cheap and plentiful.
lordbob99
515
if ur gonna run with all those hard drives and such, i'd recommend going with a larger power supply. at least a 400, if not 500 watts. without all the hard drives, i'm sure u'd be fine, but as fell8 noted, all the power being sucked may cause ur system to be extremely unstable.
sounds like a pretty sweet system ur building there tho. :)
lordbob99
jiffylube1024
7,430
That PS *should* run that setup fine. I can run with 3 HD's and basically the rest of what you mentioned with a 300W Power Supply with zero stability problems. However, with 5 fast HD's in there, I'd recommend 350-400W to be absolutely sure. 500W is definately overkill, and unnecessary. Just make sure its ATX 2.03 compatibile and has the square P4 4-pin connector.
