Do I have enough power?
cbrsmurf
Hi, I have a 350W PSU and was wondering if I had enough power to install two coolermaster 80mm fans. They say 12v and 1.8 W each.
here's my system:
amd xp2200+
coolermaster aero lite 7 cpu fan
ati9600 nonpro
one of those fan/blowers that go under the agp card
60gb maxtor 7200rpm hard drive
one CDRW drive
one wireless network card
no OCing and win2000 pro
help please
thanks
It really depends on the quality of your 350w, but you should be fine even if it is not a great brand, as you really dont have anything that will draw alot of power. An Antec or Fortran 350 usually = ~450w from a cheap no-name psu
my antec 350 i just upgraded from would handle a 2500, three hard drives a cd-rw a 120mm, a 92mm, and two 80's i thinkyou will fine.
