ok so lemme explain quickly what i did.
i got a 3rd party HSF and used that with my cpu. what i did with my stock HSF was i pulled the fan out and used it as another fan in my case. i plugged it into the port on the motherboard called sys_fan2.
the fan itself is near where the grill is on the side of the case (where the window side is).
as such id like it to pull hot air out of the system.
However, instead, it is pushing air in (even the fins are pointed such that they push air out!).
so my question is, is there any way (preferably inside windows), to adjust the fan settings.
id also like to know for all the other fans as well.
thanks.
thanks.
