Do I have a VIRUS? Please help
timers
Hi, I dont think this is a virus, but Im not sure with this Nimda crap going around. Every 1 hr on the dot, my CPU will just restart. Im not sure whats causing this, but its like as soon as it comes back up, 1 hr after that, it restarts. Im not sure on what to do, or what my problem is. Please help! Thanks.
If what you're saying is true, then I would say you have a virus. If you don't have current antivirus software you can do it over the web at pandasoftware.com, trendmicro.com and I'm sure some others.
If you're concerned that it's NIMDA, then look for two things:
1. Determine if you've got IIS installed. If you're running Win2k Server or Win2k Advanced Server, then IIS 5.0 is installed by default. If you have Win2k Pro, IIS is not installed by default, but it can be optionally installed. Open Task Manager to look for the Inetinfo.exe process -- if you find that process running (on the Processes tab), consider yourself vulnerable.
2. To determine if your system has been compromised, look for the following:
* root.exe artifact (indicates a compromise by Code Red II or sadmind/IIS worms making the system vulnerable to the Nimda worm)
* admin.dll artifact or unexpected .eml files in the directories with web content (indicates compromise by the Nimda worm).
Unfortunately, if you are infected, the only recourse is to format your hard drive.
Please, make sure you're running an AV program and update it regularly. Also, installing a personal firewall is a must. A lot of folks use Zone Alarm, but some have also reported having problems with it. I *highly* recommend eTrust EZ Firewall (made by the people who made the Inoculate AV program) along with their eTrust EZ Antivirus program. Both are very good programs, they run very smoothly and do not cause conflicts, and they do not hog system resources.
