Do home cd records work like tape records
eflat
2,109
is it that simple? I'm trying to make some recording of myself playing the piano,
i have a digital piano with rca outputs. i was thinking of putting that as the input source and using a cd recorder (not the computer kind of home stereo kind) and putting it in the tape monitor jacks and hope it records.
will that work?
royaldank
5,440
Should, but I'd recommend using a computer instead so that you can easily edit the stuff without wasting a CD (or use a CDR if possible).
eflat
2,109
Originally posted by: nakedfrog
I have no idea. You should probably just try it.
well trying it requires buyine one and i don't really want to buy something that won't work ;)
eflat
2,109
how would i do it on the computer??
eflat
2,109
it sounds complicated and not worth the trouble unless there is a proggie specificially designed to do this.
eflat
2,109
Line in to your soundcard and then record.
ugh whatever i like to keep my stereo stuff and my computer as far away from eachother as possible. i'm sure it would but my comptuter and stereo/keyboard are in different rooms and it would be so easy if i could just hook one of those suckers up to my tape recorder.
i don't ever edit my compositions (just like i would never edit my digital pictures and shoot all jpeg) so i think i am going with a cd recorder.
if they still make them. it seems like they kind of flopped. haven't heard about them in years. was there ever a really good one?
