- Aug 6, 2001
- 77
- 0
- 0
I was curious because I have a swiftech MCX370 hsf but was thinking of dumping a 92mm adapter w/ 92mm panaflo fan onto it to quiet things down. The gross airflow gain over the stock fan would be about 10 cfm, from 33 for the stock fan to almost 43 with the panaflo, while dropping noise to 27 dB from 43. I was thinking even if most of that airflow is wasted on turbulence/backpressure/whatnot it should still be able to cool at about the same level with significantly less noise.
What do you all think? Good idea? No good? I've only seen one review using a fan adapter, going from a 60mm to an 80mm, with a temp increase of 2 degrees C under full load, and no increase at idle. I was hoping with the extra volume of the 92mm fan the temp increase would be almost nil (or with luck even better
) while still killing the noise.
