PotatoSandWitch
Do I need to purchase any cables for the system I'm going to build, like a floppy drive cable or anything?
Putting a PC together is a fairly straightforward and fun learning experience, and if you run into any problems the forum members here are very helpful. Again, as long as you're buying a retail motherboard (ie. not OEM, not refurbished, not used), I wouldn't worry about the cables. Check out mechBgon's guide on building if you haven't already, it's very helpful.Originally posted by: PotatoSandWitch
Even after all the research I did to know about pc parts, now I'm starting to wonder whether I'll be able to build a functional PC. It's cheaper, and I can have everything I want, but is it hard to build PC's? I'm pretty good at complicated wire tangles, but when it gets to really technical stuff I can get lost...
Originally posted by: inveterate
Buy a Dell and it'll all be very simple..
Originally posted by: ArtVandalay
Been a while since I built, but don't retail MBs usually supply 2x IDE (one 40 & one 80) and a floppy cable? I've never seen a drive, OEM or retail, come with any cable other than the CD cable for optical drives... which is no longer even needed for modern PCs. If you're buying a retail motherboard, I wouldn't worry about it.
