Originally posted by: shabby
The extra weight might offset any mpg increase, don't forget the added cost you probably wont get back.
Originally posted by: Zenmervolt
But you're right that the difference is essentially nil in terms of overall mileage. It definitely wouldn't hurt mileage though.
ZV
ZV
Except driving stop n go, around town, where it might hurt
It probably depends if you like to drive around with cargo that has the aerodynamic profile of a picnic table. Then it might help a lot.
