Originally posted by: cmdrdredd
Originally posted by: Dropmachine
Thanks for the advice. Just ordered a set of DVI gold plated (why not?) cables from monoprice. Can't wait to see what difference they make.
Gold plating on cables has been around for quite some time, Gold conducts the electronic signal better than the typical silver plating (nickle? anyone know?). This provides better signal strength and less degredation and interference. There is not much price difference to get gold plated connectors on your cables. My point was related to branding. You can buy a store brand cable with gold connectors for say $30 (just making up a number). Would you really feel it's worth it to spend $100 on the monster cable brand because they claim to provide a better quality? Is it a $70 difference really? I wouldn't think so.
In short gold = good but overpriced name = bad (IMO)
Actually, you're wrong about gold conducting electricity better.
Gold conducts electricity worse than copper or silver. (Maybe nickel too?) The only reason gold is used is because it is very hard to corrode in normal environments. Over time, copper/silver (silver especially) will corrode and turn into their oxide forms (Silver oxide and copper oxide) which doesn't conduct electricity well at all. Gold almost never corrodes, so it has the advantage of keeping a high electrical conductivity far longer than copper, nickel, or silver.
In reality, gold on the connectors doesn't matter very much. The gold will eventually wear off after plugged it in and out multiple times. (Because the layer of gold plating is extremely thin) Then you're left with whatever layer is underneath that. (Probably nickel or copper) Beyond that, straight up copper connections won't really corrode very fast, so unless you keep them in harsh environments (High heat, humidity, dunk them in acid...) they won't be that much worse conductivity-wise over time.
At any rate however, the gold plating for the cables on monoprice is hardly any price difference, so it doesn't matter in the end.
Just remember: Friends don't let friends buy Monster cables.
