Modelworks
- Feb 22, 2007
- 16,240
- 7
- 76
I'm not sure if resolution differences truly matter in the actual production costs though (ignoring the difference in price between pressing DVDs and BRs) since both require you to take the original source, which is definitely greater in resolution than 1080p, and resize/re-encode it.
It really depends on the studio doing the releasing and the title. If it is a low budget direct to disc title then the studio will just put it on disc.
If it is a big title , important for the studio, then the cost increases substantially. Instead of just encoding it and putting it on disc they have people that go through the film frame by frame as it is being encoded making notes for where there is a problem, if the color or motion isn't what they want they manually tweak each segment so that the encoding is as close to what they want as possible. You can't do that with software. It takes someone who understands the quirks of the codecs and how to get the best output from the frame input.
I wonder if the lossless audio formats such as Dolby TrueHD help give the discs a premium in regard to licensing costs or processing time.
Dolby, DTS, Blu-Ray, etc cost the studio money. If it has a logo on the disc or box then the studio paid fees to use it.
