Do bars/restaurants pay outsiders to clean their beer taps?
Status
Not open for further replies.
Arkitech
8,356
4
I'm curious if the bars typically pay outside staff to clean their beer taps or is it usually done by in-house staff?
sjwaste
8,757
12
Check the health inspection reports for your location. A lot of places just don't clean the lines!
lxskllr
59,113
9,548
This is one of those things that it's better to not know. ;)
Whisky's a safe bet unless they those stupid pour spouts. If it doesn't get used regularly the alcohol evaporates and ruins it.
dougp
7,909
4
It depends on a lot, but I know this is how it is in TX.
If a brewery self distributes their beer, they tend to clean the lines themselves to make sure that the customer receives the best beer possible. Once it's being distributed by a distributor, then it's whatever agreement is in place between the distributor and vendor. Most lines should be cleaned once a week, and plugged when not in use.
BillGates
7,388
The Buffalo Wild Wings by my house has a guy come in to do it. Supposedly the cleaning stuff he uses is pretty nasty stuff.
sourceninja
8,805
65
I'm not a bar, but I clean my lines only when I change the keg. I use PBW which is kinda like oxyclean, then I flush with water, then I flush with starsan (a acid, food safe, sterilizer). I clean my taps the day after they get any use and I keep plugs in them when not in use. I use high end taps so they are forward sealing to prevent a lot of the problems that come with cheap taps (sticking, gumming up, etc).
Apr 12, 2010
10,510
10
Most pubs I've spoke to about it did it themselves fairly regularly.
Several times have I went in & they were cleaning on the spot, generally due to replacing kegs.
First pint out of a freshly tapped keg? Always tastes best.
Lonyo
21,938
When I worked in a pub (although in the UK, kinda) we had a guy come in on a weekly basis and clean all the lines.
DesiPower
15,299
740
what the heck are you talking about? that would totally ruin the taste of the drafts...
cardiac
14
Like dougp mentioned, around here the beer distributors have guys that make the rounds and clean the lines/taps. A couple of firemen I work with do this as their side gig. Pretty good money...
Crusty
12,684
BLC(beer line cleaner) is better for your beer lines than PBW. With a manual spray pump, some fittings, and a quick disconnect you can create a very easy system to pump BLC through your lines w/o wasting any of your CO2.
weadjust
636
I was a bartender for 5 years in a college bar. I never cleaned them or witnessed anybody clean the taps. The Budweiser guy may have but never in my presence. He would get pissed when he would catch us serving Milwaukees Best and Best Light out of the Bud and Bud Light Taps. Good times.
sjwaste
8,757
12
No shit, dude. Beast is a Miller product. Could have at least served Natty out of the Bud taps.
Status
