Do 32-Bit cards work in a 64-Bit slot?
BD231
10,568
138
A few 64-Bit PCI questions:
1.) Do 32-Bit cards work in a 64-Bit slot (looking to add a video card, ide controller and sound if possible)
2.) If 32-Bit cards don't work in a 64-Bit slot, where can I find a 64-Bit compatible video card+ide controller?
Thanks guys!
Chaotic42
34,937
2,089
Yes, but it will slow everything on that bus down to 32 bit/33MHz.
Edit: It won't make it 32bit.
Pariah
7,357
20
They will work in 64bit 33MHz slots, very few work in 64bit 66MHz slots. They will not slow down the 64bit 33MHz slots and turn them into 32 bit slots. If by chance the card does work in 64bit 66MHz slots, it will slow the entire bus down to 33MHz, again, not dropping the other slots to 32bit.
TerryMathews
Also worth noting that some 64 bit slots support 'legacy' PCI cards, the 5V signaling cards that are common. These typically are the 33MHz variety.
The 64/66 slots, like those found on the 760MPX based boards do not support legacy cards and only work with 3.3V signaling. Cards based on the PCI2.2 spec support this.
Most 32/33 cards you can buy today are still PCI2.1.
Chaotic42
34,937
2,089
Yep, you're right about it not reverting to 32-bits. It will slow down the 66MHz bus to 33 though. I've tried 4 or 5 32/33 PCI cards in my 64/66 bus and they worked well.
Bovinicus
3,145
Yes, it should work. The only way to find out is to try. You can't damage anything by plugging a 32-bit card into a 64-bit slot.
BD231
10,568
138
So in effect dropping to 33mhz kills the 64-bit badwidth though right?
InlineFive
9,599
It cuts the bandwidth by half because of the 50% speed loss so yes.
TerryMathews
Yes, you can but it's a long shot. Some (cheap) manufacturers like Koutech are making PCI2.1 (5V signaling) cards on PCI2.2 (3.3V) PCBs. Plugging a 5V card (32/33) into a 3.3V (64/66) slot is akain to plugging a 3.3V (2x AGP) card into a 1.5V (4x/8x) slot. If there isn't current overload circuitry in place, you stand the chance of blowing both card and board.
32/33 = 133MB/sec
64/33 = 266MB/sec
32/66 = 266MB/sec
64/66 = 512MB/sec
Pariah
7,357
20
You can't do that. 3.3V slots and 5V slots are keyed differently, so you can't install a standard 5V PCI card into a newer 66MHz 3.3V slot. 64bit 33MHz slots are 5volt which is why they are backwards compatible with standard 32bit cards.
TerryMathews
You obviously didn't read my whole paragraph. Some (cheap) manufacturers are making cards on PCBs that are universal (PCI2.2 or 3.3V compliant) but the design is legacy. I've got a USB2.0 Koutech card that is cut universal but it still blew an A7M266-D when I plugged it into a 64/66 slot. Because it draws 5V.
Pariah
7,357
20
PCI 2.2 does not mean 3.3V, nor does PCI 2.1 mean 5V. PCI 2.1 supports 3.3V, PCI 2.2 is the first standard to require support.
Looking at Koutech's website, they only have one USB card keyed properly for 3.3V compatibility and it has 2.2 PCI listed in the specs. Every other card is not and all but one is specified as 2.1 PCI compliant. Your problem sounds like bad luck, not something Koutech did wrong.
Koutech USB
TerryMathews
Koutech USB
PCI2.2 introduced the universal connector. The universal connector is supposed to indicate 3.3V compatability. I didn't think I needed to spell out each individual step.
I had a long conversation with Koutech's tech support. Although the card is keyed for PCI2.2 and 3.3V compatability, it is not 3.3V compatible. I can forward you the e-mails if you like.
There are a couple more cards out there. 2cpu forums is a good place to look, since the 760MPX userbase is the largest 'tinkerer' userbase of 64/66 boards out there. I seem to recall a 10/100 lan card that was keyed incorrectly, but the manf. escapes me.
