My ultimate goal is to set up domain trusts between my companies two Forests/domains which are in two separate physical locations. Both companies have their own independent .local domain set up, and we want to access resources on each network seamlessly from the other(printers, network shares, remote desktop, etc).
Each location has a Sonicwall security appliance running, and there is a permanent active VPN tunnel between them. I can ping internal IPs until I'm blue in the face from either location, it's only when I went to set up DNS that things got hairy.
ABC.local
DC= SERVERA.ABC.local
10.2.12.3/24
Server 2008 R2
XYZ.local
DC= SERVERX.XYZ.local
192.168.1.5/24
Server 2012 Standard
First attempt: I set up each DC with secondary forward and reverse zones for the other domain in DNS. Designated both servers as authoritative name servers on both sides, allowed zone transfers to/from both sides with notifications enabled. They're replicating from the masters ok, you can see the DNS records in DNS manager from either server. I can ping workstations on XYZ.local using their FQDN successfully from ServerA, I CANNOT ping workstations on ABC.local using their FQDN from ServerX.
Restarted ServerX and FQDN-based pings magically started working from both sides, but the Trust Wizard cannot find the other domain from either side.
Second attempt: Added Root Hints and Forwarders to both sides as well just to be safe, the little Add New... wizards for both had no issues resolving the opposite server via FQDN.
I can now ping "XYZ.local" from ServerA and it resolves ServerX's IP (192.168.1.5). I CANNOT ping ABC.local from ServerX, it throws the standard "name cannot be resolved" DNS error. Maybe a restart would fix this, but these are both production servers. The Trust Wizard still throws the "Other domain cannot be found" error.
Is there something i'm missing here? If the names are resolving shouldn't the trust wizard pick up on the other domain? I've tried the FQDN of the server, the ABC.local domain, just "ABC", the server NETBIOS name, from both sides of it and nada.
And before anyone suggests "Just make it all one domain and keep both DCs for redundancy!" i'd jump on that in a heartbeat if I had the time and money to properly break down and rebuild both networks from scratch and do it right
There's business reasons why I can't make that happen right now, so trusts and aggravating DNS problems it is.
ABC.local
10.2.12.3/24
Server 2008 R2
XYZ.local
192.168.1.5/24
