trying to play uncharted 3 online and it says check internet setting for nat type. then i enable dmz on router setting and it let me plays online fine! got the nat type 2 on ps3. enabling dmz makes the ps3 have nat type 2.
trying to play tekken 6 online and when search for rank match always say cannot create session or either lost connection. now tried disabling dmz and works fine! finds oponent fine.
all other games aside from uncharted 3 and tekken 6, i can play online all fine doesnt matter if enabling or disabling dmz, online can still work.
so does anyone have any solution to it? lazy to go to router setting to disable, enable dmz everytime i play uncharted and tekken. is there a solutionn to this? is there a ay to fix it to be able to play all games with online working?
cable broadbrand, wired ethernet
