Here's something that will make you beat your head against the walls trying to figure this out. I've put together a system built around a PII/450, Abit BH6 ver 1.01, 128 MB RAM, and a 10.2 GB Western Digital hd. The problem I have with this setup is that every time I try to enable DMA access in Windows 98SE for the hd, when I reboot, my system locks up when it gets back to the desktop. The only thing I can do is boot into safe mode, delete the parent IDE controler from System Manager, delete the hd and the IDE children from registry, reboot and let Windows redetect it again, and then it would be fine as long as I stayed away from DMA. I even loaded the latest drivers for the 440BX chipset from Intel, but it still happened. Yesterday I discovered the CD-Rom drive was causing this, so I removed and proceeded to reinstall Windows since I messed it up quite a bit while trying to find out what was causing this problem. Now I'm almost done configuring it and the problem started appearing again. I don't know what else to try, and I ready to go get the sledgehammer and kill this system. Pls help me before I do something I will regret. Thanks.
