Dlink router problem
LiquidVivi
58
Hello, I have the D-link 704p router and i was wondering if there is a wall to make all traffic come through no matter what. I recently am having problems logging into jetsetpoker.com and partypoker.com, both the website and client to play. This never used to happen before and i think it is the router blocking it now although i dont understand why it would suddenly block it. It is not blocked by my hosts and it seems to also block other websites like vwvortex (which is commonly posted talked about in ATOT). If someone knows whats wrong it would be greatly appreciated. Thanks
Swimmer12
31
It is called DMZ... You are opening you entire computer up to anything and anyone who wants in to your network... xxx.xxx.x.1 and choose advanced-> DMZ then go start run-> cmd-> ipconfig /all find the network adaptor ip adress and enter that address into the dmz window... the network address should be 192.168.0.xxx Click enable then you should be set to go... There is a more secure way to do that and that involves opening ports so that the program can pass through the firewall...
