Please Help -
I have the DLink 524 and Vonage. I reset the DLink last night and Vonage does not work. I need to open port ranges on the router. (10000-20000 among others). I go to ADVANCED and APPLICATIONS.
I tell it to TRIGGER PORT 10000-20000
TRIGGER TYPE UDP
PUBLIC PORT 10000-20000
PUBLIC TYPE UDP
I then apply it and do it three more times to set all the ranges up. However, no dial tone. I know it is hooked up correctly because it worked until I did the reset. Could someone please help me with this issue? Am I in the right area or should I be in VIRTUAL SERVER? The only problem with that area is taht you can only input one port at a time, not ranges.
I appreciate any/all responses.
Please Help -
TRIGGER TYPE UDP
PUBLIC TYPE UDP
