For the adventurous who are strapped for space and would like to save some money, try "rolling your own" small space VHF-TV antenna. Radio Shack sells a dipole FM antenna (RS#42-2385, $3) which is intended for FM reception. Since the receiving element is 58" long it will make a good VHF-TV antenna which can be tacked up on the wall behind curtains or a dresser. The lead-in is 300 Ohm flat, 2-conductor, ribbon wire with terminal connectors at the end. If you attach the end to the screw terminals of their indoor TV/FM amplifier (RS#15-1104, $20), you'll have a very nice, easy to mount, nearly invisible, amplified indoor antenna for under $25. The antenna is directional and may be mounted vertically, or horizontally in one direction or the other. One way to experiment is to tack the antenna to a yard stick and rotate it around to see where the best reception is. Try putting it up as high as you can. This will also make a great FM antenna for your stereo.
