DIY - Need to cut 4" hole through stucco wall
Murpheeee
3,326
I am installing a bathroom fan and bought a 4" hole saw to cut a hole through the wall and siding.
Turns out there is stucco underneath the siding and I blunted 2 drill bits just trying to drill a pilot hole before I realized thats what it was.
My hole saw it not going to cut through that stuff, its about 1" thick and hard as concrete.
So how do I get a 4" round hole through it?
iamwiz82
30,772
13
Get a good masonry drill bit and a hammer drill and make holes every 1/4"-1/2" along the perimeter, then knock it out.
At least that's what I would do.
Murpheeee
3,326
thats kinda what I was leaning toward....just wondered if there were any other options?
rivan
9,677
They don't make (as far as I know) masonry hole saws - iamwiz's method's the only reasonable one I can think of.
dullard
25,974
4,584
Ditto. But you may be lucky enough to use a regular drill. It depends on how thick the wall is. I only mention this because renting a hammer drill can be expensive, but most people already have a regular drill. True, the hammer drill will work much better though.
bctbct
4,868
Actually low pressure and slow speed you can probably penetrate 1 inch of stucco, if you only make it part through you should be able to knock out the rest of the hole in the same fashion as mentioned above.
Consider the bit one time use though.
essasin
2,777
You can either chip away at it like described above or get a sledge hammer and be accurate.
AbsolutDealage
2,675
I would strongly suggest a non-cordless drill for this... (it's amazing how many peoply only own cordless tools these days...)
Of course, if you don't have one... you probably could rent the hammer drill for less than buying a new (corded) drill. Then again, you have to return the hammer drill ;)
oynaz
2,449
Or loan the hammer drill from your brother-in-law. For some reason, brothers-in-law always onw the power tools you need. Strange but true.
AbsolutDealage
2,675
Hm... that's wierd. I must be that brother-in-law because I'd be surprised to find a hammer between the 2 that I have.
Nov 5, 2001
18,366
you COULD do it with a core bit, but you'd have to buy one or hire someone. Just get a sharp-nosed cold chisel and a hammer and bust through it.
