Hi there,
I'm looking to build my own home nas. Thje ones in the title seem to be the best choices available at the moment, but their price is high. It seems to me that we should be able to build a better system, for less money.
What components do you recommend and why?
I'm looking for:
- Lots of storage, preferably expandable (thinking of the WD Reds)
-Performance, for connections to multiple pc's. (that's where link aggregration comes in, right?
-Silence
- Energy consumption
Thanks!
p.s. also could use some help on RAID/unRAID, other RAID-like things.....
EDIT:
What this NAS is going to be used for:
- Stream HD movies to (preferably) 3 tv's at the same time. Pre-processing (not sure if that is the correct term), like Plex does, is not nessecary, that would probably need some serious hardware for 3 or mote pc's.
- A LOT of RAW (25MB) images will go on there, since i am a semi-pro photographer - cannot afford to loose those!
- It will also be used to backup some other data, from multiple sources (laptos, pc's & phones)
- I have a cheap spare 3TB NAS that i will use for backups
- I would like to download (and check and extract) files from newsgroups and torrents @ night if possible - but that will probably not be the crux here.
I would like as much storage as possible and would REALLY hate to loose the data. Of course, most valuable data will be backed up on the old nas, but still....
Hope this calrifies a bit.
Last note, a bit better than just the nessecary hardware is also great. I do like the idea of server-grade hardware. Even thinking of buying a managed switch that can handle LAG/LACP (providing the nas will support that too) if it helps speed things up.
But then again...i AM on a budget. About 1000 euro's to start with. :S
I'm looking for:
-Silence
Thanks!
EDIT:
