DIY - Case for HP Z800 Workstation Motherboard
Noo
389
10
FNG-A PC's
I know this is a bit of an old post, but I have several Z800's that I use everyday. I absolutely love them for just about everything I do; however, the Nvidia Quadro 5000 cards I use are finicky when it comes to picking up my monitors. (2x Quadro 5000 w/4 24in 1080p Dell monitors) I want to swap GPUs to two GTX 1060 but the stock 1100W PSU connections don't allow the power connections needed to do this without major rewiring. Two swap in a a normal PC PSU would mean tracing out all the pins, finding the right rails for 5V and 12V connections and a boat load of soldering. I came across your project this morning but complete accident...or miracle maybe...Where oh where did you find the power adapters for your project? I have searched the interwebs for weeks looking for exactly those connectors....I hope you get this message and thank you in advance.
Fantastic mod by the way, I love the ingenuity and drive you have to take on such a task.
Noo
389
10
Search for "10/18 to 24 Pins HP Z800 Workstation PC PSU Power Supply Adapter" they're like $15
HeavYGamerZ
7
aigomorla
21,118
3,645
you need cpu + ram + oem heat sinks.
If you do not know what those mean, or what kind you need, i sugguest you find help from someone local because that is an enterprise machine with strict part guidelines.
If you do know what parts you need, i suggest ebay would be your ideal source.
HeavYGamerZ
7
Thanks buddy my all problem solve I removed Mobo and start pc without case...see pics
Noo
389
10
Sir I have hp z800 machine I am removed my motherboard in z800 case but not removed.i all open screws like all but not remove this friends.plz help me urgently
You need to pull the motherboard toward the CD/DVD drive.
