DivX decoder applet quality settings
jaeger66
Banned
Every time I set the post processing Quality Level settings to Max in the decoder config app, they reset themselves to Min. Happens in 5.0.2 and 5.0.3, and all the other settings stick. I've seen this asked on the official forums but I've never seen an answer. Anyone who has this issue get it fixed?
you sure your system can handle it. it thought the slider could set its self based on system speed. mine doesn't change from max though
P4 2.4B, 512 MB PC3000, GF4 Ti 4400...I sure hope that's enough. Every other setting works except that one...I saw some vague replies involving refresh rates and desktop color depth but so far no luck.
You have to be playing the Divx file with mplayer2 in order for the change to stay. changing it in "decoders configeration" in START, programs, divx doesn't help mush.
Here's what you do:
Go to "start" then "Run"
Now,, input "mplayer2" without the" " then [enter]
The old media player should open, now open any divx file
when the file is playing , right click on the screen then select "properties" then "Advanced" now select "divx decoder filter"
Now move the slider to the max, click "apply"
Your setting will now stay.
But Even with the setting at Max it doesn't improve a whole lot. it will only help smooth out the high compress qualitys a little bit. For the new nicely encoded divx, you wouldn't even notice it much.
I like ffdshow's post processing more, because there's a auto setting, and it use around 50% less cpu power than the normal divx decoders.
