Diving on the US Navy ND tables is a recipe for trouble right?
dug777
24,778
4
I recall being told that they are pretty much on the limit stuff for ultra fit SEALs, and certainly my PADI tables, and computer are a lot less generous...
I really can't imagine doing deeper dives without a computer any more actually, and a five at five in blue water would be just about impossible without the detailed digital depth guage they have ;)
Ns1
55,420
1,600
Originally posted by: dug777
Originally posted by: NeuroSynapsis
wdaquapbasdjkf?
well it is called off topic, not 'Nef Topic' ;)
i was referring to the manner in which you made the statement. it sounded like wdaquapadosjfalksdfsa (i can't remember his name for the life of me)
dug777
24,778
4
Originally posted by: Yossarian
sometimes people include laymans terms so non geeks can understand their posts.
meh, if you don't understand my post then you sure as hell wont be able to answer me usefully on this topic i suspect ;)
dug777
24,778
4
wdaquapbasdjkf?
wdaqng or something right?
RedCOMET
2,836
More than likely, but for us laymens, reading a topic that we don't know much about (like this one) helps us learn. and learning is cool ;)
QuitBanningMe
Banned
Mar 2, 2005
5,038
which will end up happening........................................
Basically Dug would like to disorient himself while diving and die....................
dug777
24,778
4
:thumbsup:
US Navy No-Decompression tables list the safe amount of time you can spend at certain depths without having to do decompression stops (to get nitrogen out of your tissue) on the way back up ;)
surreal1221
1,206
So the trans quacriom equation explains that the true velocity of motion minus three pints of whale urine leads to a much deeper and harder penetration of all equations. /out
notfred
38,241
4
I nominate this for psot of the day.
TreyRandom
3,346
If you're a recreational diver (and NOT a Navy SEAL), you shouldn't dive using Navy dive tables... unless you really don't mind the consequences. I'm a PADI Divemaster, and I'd never consider using anything but my dive computer, and even then, I also stay within manual dive table calculations. Never know when your computer will give out midway through a dive and you need to know how long you can stay down... or how long you need to stay up once you've surfaced.
dug777
24,778
4
yeah, i always set the bezel on my divewatch as i go in, just in case.
wfbberzerker
10,423
wdaquapbasdjkf?
wduaqnug
Biggerhammer
1,531
You're actually posting a request for hyperbaric information/advice to ATOT? Even if there is a genuine expert out there his/her post will be buried with Soviet Russia nefs and spider posts.
UWDawg
298
Semi true. The Navy dive tables are compiled using average standards for Naval personnel, more specifically the dive community. These tables are used by all military divers e.g. the Army Corp of Engineers, deep sea divers (mixed gas), Naval EOD, Spec War...These personnel are of different physical fitness.
What it comes down to is your health. The more the body fat you have the more the risk you get from A.G.E. The same holds true about your cardiovascular system.
If you look through the history of the dive tables and track the changes, you would notice that dive times have been decreasing for all depths. This basically means don't push your luck or your limits.
