Coils rarely fail. Unless they are VERY old, like yours. They get replaced a lot, but usually aren't the cause of whatever problem they are bought to fix.
Points suck. You need an electronic distributor of some sort. Getting one of those, with a good magnetic trigger will be a good thing.....THEN, you will benefit from a different coil. Otherwise, you're wasting your money just putting a coil on the points system. What's going to make the coil put out more is the electronic module that's driving it.
So I see there is a conversion for the Chrysler stuff. That's good....the Chrysler electronic module is a good one, from what I've heard.
Here's a tip: Don't look at the voltage ratings of coils. They are mostly irrelevant....any good coil will do. Any gas engine, up to and including Nascar and even Fuel engines, only need about 45000 volts to fire reliably.
Changing the plug gap will significantly change the voltage the coil puts out. Reason being, it has to saturate a tad longer to build up enough energy to jump the larger gap.
There is a point of diminishing returns, though....much bigger than .050" or so, and you lose amperage....but changing the plug gap from what the stock setting is...probably .030-35" or so, to .045" will up the voltage of the coil and put you in the "sweet spot" of gap/voltage/amperage, where you get the best power/mileage.
There is also the option of switching to an HEI distributor. I mention this since you say you want all new parts. Originally a GM product, they are made for about any domestic V-8 now. They usually come complete, with one-wire hookup. Coil, module contained in one unit.
Keep the plug gap thing in mind with these....some makers claim you can run .055" gap on them.....while on any system, the larger the gap gets the more voltage you'll get, you also run the risk of the spark deciding to find an easier path to ground than the plug electrode.
The HEI would be a much easier way to do it than all that wiring harness crap, and separate module and coil mess. One wire to power the HEI, and run your plug wires...set the timing and DONE.
