I have an E8400 and 8800GTX at stock speeds on air cooling. Originally I intended to have some fun OCing them, but the sheer amount of heat that they produce has made that impossible. Mostly because the room noticeably heats up, but I also wouldn't want to push the temps on the processor/gpu much higher for longevity reasons.
Today, as I sat baking sitting at the computer, I had an idea. What if I used water cooling and mounted the radiator outside of the room? It would probably have to be mounted above the door however, which might cause some problems with extra distance and height. The other possibility is right by the window, although that is an even longer distance.
So that brings me to a basic question. How much distance/height increase can a standard water cooling pump handle?
