Displays/Monitors with EXTERNAL power supplies
cautery
I am looking for current gen monitors/displays that use external power supplies.
For my purposes, I need to eliminate switching power supplies from all sources when/if possible.
I can substitute a linear supply at whatever the required supply voltage is... 12, 19vdc, et al.
Also need them to have VESA connector bosses in the case for mutiple monitor mounting on suspended mounts. Up to 22 or 23" wide, height not limited.
Thanks!
I thought external supplies were extinct, but it appears that both HP and ASUS make lots of them.
I'll likely grab a pair of the ASUS ones.... they have many choices... depends on what you want to pay. 😉
