FrankRamiro
Hi guys; i have a question;is there any software to display winxp side ways on the monitor?
Your video card's control panel should be able to rotate the display.
Irotate is freeware that allows you to rotate the screen image.
http://www.entechtaiwan.com/util/irotate.shtm
Hold down the 3 keys "Left Ctrl - Left Alt - Left Arrow" at the same time, Ctrl-Alt-Up to switch back (works for me anyway).
Ahhh, you're right. I just tried this on my AMD C-50 netbook and it didn't do anything (only works on my Intel machines). Good to know.Those are Intel video driver specific hot keys.
