Display quality issue with Quake 4 and X1800s
nRollo
Banned
Originally posted by: ArchAngel777
Fix the link, it has too many HTTP's in it.
Edit ** Maybe it is my system that is whacked... Hmmm Odd, when I click on those links, it displays extra characters and thus the wrong webpage. Other links work fine though.
I don't think ATI wants you to see their dirty laundry Arch Angel.
If you search "issue" on their web page though, you'll see these and the rest! Scandalous!
nice words for saying you have nothing better to do on a saturday night.
so you will DEFINITELY get any game ati is bad at? so i can assume you don't own half life 2?
i can't reply with anything constructive because the links are broken 🙁
I tried to re-do the links, but they don'd work. 🙁
Like I said, search "issue" on ATIs website and you'll see them.
I want WHQL drivers that play them right!
Better dump those 7800s then because you won't get it on them either:
Issues Resolved in Version 81.87
GeForce 7800 GT/GTX: Reflections are corrupt when set to high in Serious Sam 2.
GeForce 7800 GT/GTX: Cyan-colored pixels appear randomly on the water tower in F.E.A.R.
Whoops, looks like your WHQL nVidia drivers have problems with Serious Sam 2 as well FEAR and require beta drivers to fix them. When can we expect your thread blasting nVidia for those issues?
As for your "trouble-free" nVidia drivers, including the SLI situation you claim is "problem free" and everyone else is spreading "FUD" because they don't own the cards:
Open Issues in Version 81.87
? Dual GeForce 7800 GT/GTX: Everquest 2 launches to a black screen when antialiasing is set to 2xQ at 1920 x 1200 resolution.
? GeForce 7800 GT/GTX: Text flickers on and off and sometimes rendering stops in Fable on the Dell flat panel.
? GeForce 7800 GT/GTX, Windows XP MCE: Video skips intermittently when playing HD network transport streaming clips.
? GeForce 7800 GT/GTX, GeForce 6800: Corruption of Widescreen great shot playback mode is corrupt with AFR2 mode set in Tiger Woods 2006.
? GeForce 7800 GT/GTX: The display becomes blurry with Gamma AA enabled on Grand Theft Auto San Andreas.
? GeForce 7800 GTX: Text in the game Fable flickers on and off, and sometimes stops rendering, on a Dell flat panel display.
? GeForce 7800 GTX, Windows XP: When changing to a resolution higher than 1024x768 in Need for Speed Underground 2 on a 1920x1200 widescreen flat panel, the application attempts to select the next resolution it has above 1024x768, which is 1280x960 and not supported by most flat panels. A known workaround is to manually add the mode 1280x960 from NVIDIA's Custom Timings control panel and then continue to select the resolution needed.
? GeForce 7800 GTX, Windows XP: The desktop becomes shaky when changing the resolution to 1920x1080 on a Viewsonic VP231wb.
? GeForce 7800 GTX Windows XP MCE 2005: Some artifacts appear when de-interlacing is enabled on 1920x1080i video clips.
? GeForce 7800 GTX, Windows XP MCE 2005: NVIDIA PureVideo Decoder inverse telecine does not work correctly in 480p and 1080i output mode.
? GeForce 7800 GTX, Windows XP MCE 2005: Changing the video acceleration while using Windows Media Player 10 to play PBS -Omaha Zoo RR.mpg crashes the application.
? GeForce 7800 GTX, GeForce 6800, Quadro FX 4500: The system slows down with the Liquid Edition SD timeline.
? GeForce 7800 GTX / GeForce 6800 Ultra: Age of Empires 3 demo v1.0 has corruption on the title screen when running at high resolutions (1600x1200) with antialiasing set to Medium or High, Shader Quality set to Very High, and Shadow Quality set to Very High. GeForce 6 Series
? GeForce 7800 GT/GTX, GeForce 6800 Ultra, SLI: The NVIDIA panel intermittently prompts for a reboot after enabling dynamic SLI coming out of Dualview.
? GeForce 6800, Windows XP MCE: While Windows Media Player 10 is playing a video file, MCE shows a blank screen when launched.
? GeForce 6800 Ultra: Textures are corrupted upon the first time entering a zone in Guild Wars.
? GeForce 6800 Ultra / GeForce FX 5950 Ultra: Battlefield 2 has corruption or crashes when a player switches from zoomed commander view to zoomed sniper view.
? GeForce 6800 Ultra: Age of Empires 3 Demo has a corrupt square near the lower right when switching to or from all modes (except 800x600 to 1600x1200).
? GeForce 6800 Ultra: There is pausing and corruption in Tiger Woods 2005.
? GeForce 6800 Ultra: Prince of Persia: Warrior Within either stops functioning or crashes to the desktop.
? GeForce 6800: Shadow corruption occurs in the game Lineage II.
? GeForce 6800: A small square of bad pixels appears in the lower right corner of the window when changing to 1600x1200 4xAA and 8xAF in Age of Empires 3 and Colin McRae 2005 with highest quality settings enabled.
? GeForce 6800, SLI: The audio is corrupt during the intro videos in Flat Out when SLI is enabled.
? GeForce 6800: Shimmering or cropping of the full-screen video mirror occurs when covering the video window with another window.
? GeForce 6800, SLI: Stuttered rendering occurs during test 3 in 3DMark05 at 1600x1200 4xAA with SLI enabled.
? GeForce 6600: There is corruption in the water in the Painkiller benchmark.
? GeForce 6600, Windows XP MCE: Video error occurs with Live TV when switching between Live TV and full-screen DOS.
? GeForce 6600, Windows XP MCE: While playing MCE Live TV in Clone mode with full-screen video mirror, the mirrored display is corrupted when resizing the application.
? GeForce 6200 128 MB, Windows XP MCE 2005: MCE is not recovering properly when moving the applicatin from one display to the other while playing a WMV HD file.
? GeForce 6200 16 MB with TurboCache: The system crashes when playing a media file with nStant Media in full-screen mode.
? GeForce 6200 with TurboCache (16 MB), Windows XP: Everquest 2 crashes or hangs when run at 1600x1200.
? GeForce 6200 with TurboCache, Windows XP: Unreal Tournament 2004 has intermittent grayed-out screen with antialiasing enabled.
? GeForce 6200 with TurboCache, Windows Media Center 2005: After switching DVD playback to full-screen mode, the screen turns blank and then the desktop corrupts when returning to windowed mode.
? GeForce 6200 with TurboCache (16MB): The system crashes when resizing applications.
? GeForce 6200 with TurboCache (16MB), Windows XP Media Center Edition 2005: Full-screen video mirroring is not supported.
? GeForce 6150/6100: Battlefield 2 has high frequency flicker of horizontal bands scanning across the screen on bright backgrounds.
? GeForce 6 Series, Windows XP: Some animated characters in World of Warcraft have black or missing textures. GeForce FX Series
? GeForce FX 5950 Ultra: Call of Duty 2 crashes when optimal system settings is chosen in the game options menu.
? GeForce FX 5950 Ultra: Dungeon Seige 2 intermittently hangs with a black screen.
? GeForce FX 5950: Ultra Age of Mythology has screen flicker with certain special effects.
? GeForce FX 5200: There is corruption in the Far Cry heads up isplays.
? GeForce FX 5200 Ultra, Windows Media Center Edition 2005, NVTV: Live TV hangs when running in DualView mode with Video Mirror enabled.
? GeForce 7800 GTX, SLI, WIndows XP Professional x64: Half-Life 2 Day of Defeat does not run.
? GeForce 7800 GT/GTX, SLI: Non-active displays are activated after disabling SLI or rebooting the system.
? GeForce 7800 GT/GTX, SLI: Display does not respond appropriately when using Pan-and-scan under SLI mode.
? GeForce 7800 GTX SLI: SLI auto display-detection does not detect displays attached to the slave GPU. This happens when switching output or during boot-up. It is recommended that you use SLI with your monitor connected to the GPU closest to the chipset in this driver (GPU1).
? GeForce 7800 GTX SLI: Everquest 2 launches to a black screen when antialiasing s set to 2xQ.
? GeForce 7800 GTX, SLI: Attempts to enable SLI dynamically occasionally fails, requiring a system reboot.
? GeForce 7800 GTX, SLI:The PrintScreen function does not capture 8xS AA, 8x SLI AA, and 16xS SLI AA correctly in Half-Life 2
? GeForce 7800 GTX, SLI, Windows XP: The computer crashes intermittently when changing the desktop resolution to 1920x1080 on a Viewsonic VP231wb.
? GeForce 7800 GTX, Windows XP Media Center Edition 2005 Update2: When running in window mode, there is tearing in the video on the top of the screen when playing MPEG-2 high definition clips on HDTV output. This is an application issue with Media Center and does not occur if you run Media Center in Fullscreen mode.
? GeForce 7 Series / 6 Series, SLI : The control panel may prompt for restart when switching to SLI mode from DualView mode after changing the primary display. It is not recommended to use DualView mode with SLI GPUs at this time.
? GeForce 7 Series / 6 Series, SLI: Enabling SLI with a monitor connected to the second GPU causes the display to go black. It is recommended that you use SLI with your monitor connected to your GPU closest to the chipset in this driver (GPU1).
? GeForce 6800, SLI: If SLI antialiasing is enabled, the regular antialiasing modes are not available after disabling SLI. The regular antialiasing modes will be available if you disable SLI antialiasing before disabling SLI.
? GeForce 6800 Ultra, SLI: There are intermittent application failures when using nForce4 SLI/SLI X16 motherboards.
? GeForce 6800 Ultra SLI: Screen goes blank when changing to the digital flat panel on the secondary SLI GPU.
? GeForce 6800, Windows XP, SLI: There is a large performance drop in Far Cry when 8x SLI antialiasing is enabled, compared to 4x antialiasing.
? GeForce 6800 Ultra, SLI: Apple 30 inch display does not run with 512 MB graphics boards in SLI mode. You must switch to single GPU mode to work.
? GeForce 6600, SLI: The Select display output option is not available for NVIDIA SLI without the SLI connector (?bridgeless? SLI configurations). This is a known limitation of NVIDIA SLI when the SLI connector is not used.
? GeForce 6600, Windows XP, SLI: The system occasionally hangs when playing Everquest 2.
? GeForce 6600, Windows XP, SLI: When the quality level is set to Extreme Quality, EverQuest 2 does not render correctly with 4x antialiasing enabled at 1600x1200. The problem does not occur at any other resolution, or with 2x antialiasing enabled, or when a lower quality level is set in the game.
? GeForce 6600, SLI, Windows XP: Gameplay and menu performance drops when running Kohan 2: Kings of War in SLI mode with 4x antialiasing enabled.
? GeForce 6600, SLI, Windows XP: Lock On: Modern Air Combat has lower than expected performance at high resolutions with antialiasing enabled.
? GeForce 6600, SLI, Windows XP: Corruption occurs in the game Painkiller when setting the resolution to wide screen formats.
? GeForce 6600, SLI, Windows XP: The entire display blacks out briefly when attempting to bring up the NVIDIA Control Panel.
Originally posted by: BFG10K
Wow, great response there Rollo. Like you said in forums issues. clearly you are no child. :roll:
You two just need to get along... You both have some good information. Have a drink on me... Wait, Rollo, no drink for joo! You been drinking to much already tonight 😀
LOL good post
So what's the thread about? that the x1800 cards have IQ problems on those games? Doesn't that happen to a lot of cards (nvidia and ati) with a lot of games?
I'm confused.
It must be my bedtime 🙂
hehe.. that's kind of the point.. honestly, cards from either company really do work well overall, it's just sometimes ppl make huge deals about minor issues.. the more things change, the more they stay the same? 😉
I can't help but feel the X1800's were either rushed, or they're just something to distract people from something else in development.
I think the rush job is a more stable idea.. As for nVidia, I can't say I've used, looked at using, considered using any of their cards..
Though, that four way SLI was really really tempting..
