Display driver crash when time spy - only when i turn on monitor from standby.
lpio211
56
Hi. I tried to reproduce 2 times display driver crash. When i run 3dmark time spy stress test. I turn off monitor and then turn on again it will stop test and display TDR crash report in event viewer. Is this reason to worry? This happened 2 times when i turn off montor and turn on back. I tried to reproduce this more than 2 times,and no crash. Yes test will stop , but no TDR driver crash. Weird.
PC: 6700K stock 16GB DDR4 Asus Z170-P Corsair 750 RM 1080 Ti Fe stock No oc.
Screen from event viewer:
https://postimg.org/image/18ats31j57/
Any ideas why it crashed driver only 2 times during this?
My monitor: iiyama red eagle g-master gb2488hsu-b3
If i dont turn off monitor test will run non stop even 24 hours without crash.
Monitor is display port to DVI.
Puffnstuff
16,255
4,928
What driver version are you using and have you tried more than one driver version to see if it makes a difference? The most current is 388.0.
lpio211
56
The fact is that i don't get a TDR every time after turning on monitor when the test stop . Its very random. Anyway dont worry about this?
No reason to search for problems? It TDR at random times just when i turn on monitor during test. Test will stop and sometimes tdr will show in event logs. Thats all. Not hardware issue? Its last question. Thank you .!
