- Jul 11, 2007
- 276
- 0
- 76
Hi all, got a weird situation at hand. I have a bunch of Sony DVD+RW discs I'm currently having issues with. The discs are fairly old (5 years+?), but still fresh with no writes on them. I'll try to break it down for easy legibility.
1. On laptop #1, I can burn & format (1st time format) a FRESH disc. After burning, the same disc can not be read. After popping in the drive, the drive just makes some weird noises, but does not even recognize there's a disc inside.
2. On external DVD-RW drive, said disc is READABLE. However, I can not erase/format the disc for further re-writing. I just get errors when I try to erase the disc (ImgBurn & built-in Windows burner thing).
3. On laptop #2, EVERYTHING works. Previous unreadable/un-erasable discs work just fine on Laptop #2.
I never had ANY problems with the drive on Laptop #1 or the external before. So, does this look like a burner issue, or are my discs starting to rot or something? Any insight would be great! Thanks in advance.
