Disconnections on wireless (but not wired) network connection...ideas?
Entity
10,090
I'm noticing that on my wireless connection, any time I'm playing poker online (pokerroom.com, pokerstars.com) I get disconnected. If I play downstairs, on my wired connection, I get no disconnections. Both computers are hooked up to my Dlink 614+, so they are both behind a router. Any idea how I should go about diagnosing this?
This is the ONLY problem I've ever noticed with this router, FWIW.
Rob
Entity
10,090
Here's the results of a netstat -a while I'm playing (and getting Warning errors):
C:\Documents and Settings\Rob>netstat -a
Active Connections
Proto Local Address Foreign Address State
TCP ion:epmap ion:0 LISTENING
TCP ion:microsoft-ds ion:0 LISTENING
TCP ion:1025 ion:0 LISTENING
TCP ion:1086 ion:0 LISTENING
TCP ion:1788 ion:0 LISTENING
TCP ion:2018 ion:0 LISTENING
TCP ion:5000 ion:0 LISTENING
TCP ion:5679 ion:0 LISTENING
TCP ion:1787 ion:0 LISTENING
TCP ion:1787 localhost:1788 ESTABLISHED
TCP ion:1788 localhost:1787 ESTABLISHED
TCP ion:netbios-ssn ion:0 LISTENING
TCP ion:2018 66.212.235.6:5700 ESTABLISHED
TCP ion:2020 192.168.0.1:5678 TIME_WAIT
TCP ion:2023 192.168.0.1:5678 TIME_WAIT
UDP ion:microsoft-ds *:*
UDP ion:isakmp *:*
UDP ion:1028 *:*
UDP ion:1060 *:*
UDP ion:1075 *:*
UDP ion:ntp *:*
UDP ion:1036 *:*
UDP ion:1900 *:*
UDP ion:ntp *:*
UDP ion:netbios-ns *:*
UDP ion:netbios-dgm *:*
UDP ion:1900 *:*
I'm not sure if the disconnetions are specific to the laptop itself (these are both on downloadable clients that don't rely on java) or specific to the laptop. Any ideas how to figure out?
Rob
Entity
10,090
Ok, I'm trying to play the same games right now with the laptop hooked up to a wired port (still behind the firewall though), and it works just fine. Any ideas?
I've turned WEP off, still no luck.
Rob
Entity
10,090
Reset router to factory settings; I have no idea what could be causing this. :|
Ideas?
Edit: Analyzing my router logs, I don't see any reports of dropped packets at the router level. Are there any diagnostic tools that I should run for my Wireless connection?
Rob
Entity
10,090
Switched wireless cards on my laptop, now I have no issues. Maybe my TrueMobile is at fault. :|
Rob
Entity
10,090
Just an update, updated firmware seems to be helping so far. :D
Edit: Helping, I guess, but still having disconnects. :|
Rob
