Disassembling Presario Laptop, need help!
jupiter57
Anyone ever remove a keyboard on a Compaq Presario 700 series (730) laptop?
I'm trying to get this laptop apart to replace the charger receptacle, I have removed all the "star" bit screws on the bottom, as well as all other screws visible, along with the DVDRom.
I can get three corners to release, but the last corner is still held firmly in place!
Any help, advice, link, or insight with this will be greatly appreciated!
A million thanks to you!!!
It also helps to note I may also require a "charger board", I had not anticipated that but it may be easier in the long run.
