After reading good things about this drive, I bought one (OEM) to replace my Toshiba 40x drive that was starting to die.
First, I installed the drive, flashed the firmware to 3.0A, and enabled DMA on the IDE channel in Win2K. This resulted in a complete machine lockup when trying to run CloneCD. I tried all different configurations of Primary and Secondary, Master and Slave and the problem kept happening. So, I had to settle for PIO mode (which seems to work fine)
Next, I tried CDSpeed99 and CDDAE99 . These benchmarks showed terrible results in the data transfer test (8x - 9x) and DAE (< 8x). I partially solved this problem when I downloaded the speed setting utility from Teac. For some reason, the default setting for this drive is 10x (figure that one out!) so I used the utility to set it to 17x-40x. This improved the transfer test to about 22x average and DAE to 17x average. This is still well below my expectations since the CDSpeed2000 site shows DAE at 30x. My Toshiba drive was faster at the transfer test but only had about 11x DAE average and did not have a problem with DMA enabled.
Did anyone else have this problem with DMA enabled for this drive?
