Disabling thermistor on 'smart fans'
mcoski
855
I remember reading an article way back when, where a small mod could make a thermistor fan run at full power all the time and disable the temp readings. Anyone know how or have a link to how to do it? I am thinking of picking up some silenx fans for my new shuttle coming in and want to do this mod, thanks.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
It's the other way around. Thermistor resistance drops as the temp increases, so shorting the leads together will give max rpm...
I wouldn't spend the extra for the silenx fans if you don't want the temp-control feature- there are several good quiet fans available for a lot less, Enermax and others even offer some with manual adjustments.
