Disabling onboard sound on A7M266-D
Ramatoulaye
26
Well, I found a website which says that i switch jumper AUDIO_EN from 1-2 to 2-3 to disable sound...but i find no mention of audio_en in the manual, and i can't find it labeled on the board itself...
It tries to take control of my audigy , and miraculously unistalls the drivers for it every 3 reboots, so it is very very annoying.
Anyone know where the jumper is?
A7M266-D v 1.04, dual morgan 1.3's, 512 of 2100 (unregistered), gf4ti 4200 (gainward, has some problems), audigy, etc....
thanks in advance
Buz2b
4,619
Look in two places for it. One is just in front of the PCI slots. There are a series of jumpers not mention in the manual there. The other place is between the last and next to last PCI slot. Again, not labeled in the manual. The first location is where I found it on my A7M266 (Not D). Same problem of no labeling in manual too. It is there, and it is stenciled on the PCB but get out your magnifying glass cause it's hard to see. Good Luck.
Just a thought but you might want to check with the AMD MB Asus Forum. They have a good database and many owners there.
