Hi,
I have been going through hell trying to solve this problem. The symptoms of my problem are that Direct3D (D3D) graphics are garbled. There are polygons flying all over. This is apparent in any D3D game, and also in the DxDiag D3D test. On this same hardware (except for power supply, which I replaced recently after my previous stopped working) D3D games would work fine. BTW, OpenGL games such as Quake 3 and Return to Wolfenstein work fine.
First let me tell you about my system
Abit KT7-RAID "64" BIOS
AMD Athlon 900MHz
256MB Mushkin PC133 Rev. 2
ASUS V-7700 Pure GeForce2 GTS 32MB
SBLive! Value
Creative PC-DVD Dxr2 Decoder
3COM Etherlink III PCI Bus Master 3C590
Adaptec 2940 SCSI-2 PCI Controller
PC Power&Cooling Silencer 400ATX power supply
GlobalWin FOP38 with Sanyo-Denki PICO ACE 25
Win98SE (4.10, Build 2222) A
DirectX 8.1 (4.08.01.0881)
ASUS V7700 6.33 video driver (latest "official") 800x600 100Hz 16bit color
VIA 4.37V 4-in-1 driver
Highpoint driver 1.11.0512 (to match 1.11.042 embedded in BIOS)
I have tried many things to remedy the situation and none have affected the symptoms displayed in D3D games (such as my longtime favorite Viper Racing) and in the DxDiag test.
tried latest nVidia Detonator driver (23.11)
tried latest ASUS beta driver (14.62a)
removed all other cards in motherboard in case of IRQ conflicts
removed memory sticks, rearranged memory in slots
replaced video card with VisionTek GeForce2 Ti 200
replaced motherboard with ASUS A7A266
did completely clean install of Win98SE on formatted HD
disabled HPT370 RAID controller
disabled USB
set BIOS to "failsafe" defaults
set BIOS to the recommendations of many people (AGP Multiplier 4x, fastwrite enable, video bios cache disable, video ram cache disable, plug & play OS no, AGP Master 1 WS write/read enable, P2C Concurrency enable, video palette snoop enable, delay transaction disable, PCI Master timeout 0, PCI Master read cache disable)
adjust IO voltage from 3.3V down to 3.2V (lowest possible on MB) and up to 3.5V
unplugged any components not needed (in case of power issues)
None of these made any difference. Please help me with this problem, it is consuming me on my vacation, and I have so many games I have been waiting to play that I now cannot.
Thanks,
Aubrey
rhys@mit.edu
AMD Athlon 900MHz
SBLive! Value
disabled USB
Thanks,
Aubrey
rhys@mit.edu
