direction of case fan and stability
nxh
248
i have a antec case and i am not sure which direction the case fans should be facing for optimal circulation.
i figure the back fan blows air in and the front fan should blow air out. Is this correct or does it even matter which direction air flows.?
Also what do i use to hold up the case fan in the back. Is there a special adapter?
Currently using tape but does not look professional and stable.
dbcrossfire
670
i have a 1030b and it came with these nifty purple things you mount the fan into and then pop the purple things in the the back of the case.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,686
In general, the rear fan exhausts while the front pulls air into the enclosure. Kinda like this:
AMD
Fans must fit the enclosure, when they do, the mounting holes are obvious and fans can be attached with screws and nuts or special fan screws, available from a variety of online vendors like 2cooltek or millisec, maybe even from a local electronics shop or radio shack.
