- Feb 9, 2000
- 415
- 0
- 0
I have a HP burner at work and a plextor at home and routinely use discs to ferry work back and forth between the two locations. I gave up using CDRWs a long time ago and now use CD-Rs formatted to DirectCD. The only reliable way I can get this to work, is when ejecting the disc from either pc I have to select the option to convert the contents to a format compatible with any CD-R, CD-RW, etc. If I just Eject leaving the discs as is, 9 times out of 10 I won't be able to read the disc in my plextor.
Now then, you might think my Plextor is bad but I don't think so as I have no problem burning all manner of discs with it.
But I was wondering if anyone else noticed a problem like this and if so what you did about it...
