Direct3d and Direct draw Not available???
ceige6542
Hi All
Having problems with PC at moment where i cant enable any of the options for Direct Draw and Direct3d in DxDiag, I'm not sure when this happened as i dont use PC for games and it was only because i went to play a dvd that i noticed the problem.
I have Updated The video card drivers and the motherboard drivers to no avail. DxDiag does not report any problems with any files. I have contacted ATI regarding this but they was not help and blamed the motherboard in the end.
I know it does work as i have played DVD's before (ALSO Screensavers dont work now)
Below is the dxdiag report and a report from ATI's report utility.
Any Help would be great.
DxDiag Report
System Information
Time of this report: 11/10/2005, 00:40:13
Machine name: MAIN
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 Processor 3500+, MMX, 3DNow, ~2.2GHz
Memory: 2048MB RAM
Page File: 278MB used, 3152MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9600 SERIES
Manufacturer: ATI Technologies Inc.
Chip type: ATI RADEON 9600 Series AGP (0x4152)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4152&SUBSYS_7C29174B&REV_00
Display Memory: n/a
Current Mode: 1152 x 864 (32 bit) (75Hz)
Monitor: SyncMaster 171S/ 175S/ 170S, SyncMaster Magic CX175S-AZ/LX175S
Monitor Max Res: 1280,1024
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6575 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 9/15/2005 02:58:47, 241664 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 9/15/2005 02:58:28, 1339392 bytes
Device Identifier: {D7B71EE2-0212-11CF-546D-235CA1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4152
SubSys ID: 0x7C29174B
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Audigy Audio [9000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_10071102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0383 (English)
WHQL Logo'd: Yes
Date and Size: 4/11/2003 05:32:36, 502160 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 192000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Audigy DirectMusic Synthesizer [9000], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB Audigy Audio [9000], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy Synth A [9000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy Sw Synth [9000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy Synth B [9000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy MIDI Port [9000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy MIDI Port [9000] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0A81, 0x0101
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x00E7
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 06:08:42, 57600 bytes
| Driver: usbd.sys, 8/23/2001 21:00:00, 4736 bytes
+-+ Logitech Cordless USB Mouse
| | Vendor/Product ID: 0x046D, 0xC50E
| | Matching Device ID: usb\vid_046d&pid_c50e
| | Service: LHidUsbK
| | Driver: LHidUsbK.sys, 4/26/2004 06:10:00, 38081 bytes
| +-+ Logitech HID-compliant Cordless Mouse
| | | Matching Device ID: hid\vid_046d&pid_c50e
| | | Upper Filters: LMouKE
| | | Lower Filters: LHidKE
| | | Service: mouhid
| | | Driver: mouhid.sys, 8/17/2001 12:48:00, 12160 bytes
| | | Driver: mouclass.sys, 8/4/2004 04:58:32, 23040 bytes
| | | Driver: LHidKE.Sys, 4/26/2004 06:09:24, 24605 bytes
| | | Driver: LMouKE.Sys, 4/26/2004 06:09:42, 71405 bytes
| | | Driver: KHALMNPR.Exe, 4/26/2004 06:06:12, 29696 bytes
Gameport Devices
+ PCI standard PCI-to-PCI bridge
| Matching Device ID: pci\cc_0604
| Service: pci
| Driver: pci.sys, 8/4/2004 06:07:46, 68224 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7003&subsys_00601102
| | Service: ctgame
| | Driver: ctgame.sys, 12/30/2002 04:53:36, 12160 bytes
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 05:58:34, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 05:58:32, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 08:01:07, 40840 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 252.8 GB
Total Space: 286.2 GB
File System: NTFS
Model: Maxtor 6B300S0
Drive: O:
Free Space: 34.7 GB
Total Space: 238.5 GB
File System: NTFS
Model: WDC WD2500JB-00EVA0
Drive: D:
Model: ATAPI DVD RW 8XMax
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 05:59:52, 49536 bytes
Drive: E:
Model: PIONEER DVD-RW DVR-108
System Devices
Name: Sitecom Wireless Network PCI Adapter 54G WL-115
Device ID: PCI\VEN_1814&DEV_0201&SUBSYS_9073182D&REV_01\4&3191A3E6&0&3070
Driver: C:\WINDOWS\system32\DRIVERS\RT2500.sys, 3.00.0001.0000 (English), 12/15/2004 18:12:04, 218368 bytes
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_086C0574&REV_46\4&3191A3E6&0&6070
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 06:10:08, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 06:10:06, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 05:58:29, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 05:58:29, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00601102&REV_04\4&3191A3E6&0&3970
Driver: C:\WINDOWS\system32\DRIVERS\ctgame.sys, 5.12.0002.0100 (English), 12/30/2002 04:53:36, 12160 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\4&3191A3E6&0&3A70
Name: Creative SB Audigy
Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_10071102&REV_04\4&3191A3E6&0&3870
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 07:56:42, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 07:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 06:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 06:07:58, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/4/2004 06:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 06:08:02, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 07:56:57, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.0381 (English), 3/25/2003 12:11:24, 134656 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.0383 (English), 4/11/2003 05:32:36, 502160 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0381 (English), 3/25/2003 12:12:54, 190176 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.0381 (English), 3/25/2003 12:13:02, 6144 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0381 (English), 3/25/2003 12:13:20, 135696 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.0381 (English), 3/25/2003 12:13:30, 144736 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.0382 (English), 4/3/2003 02:59:46, 850880 bytes
Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.0383 (English), 4/1/2003 12:07:58, 142752 bytes
Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0003 (English), 3/13/2003 11:10:36, 15840 bytes
Driver: C:\WINDOWS\system32\ctdlang.dat, 3/25/2003 12:37:36, 200089 bytes
Driver: C:\WINDOWS\system32\ctstatic.dat, 3/25/2003 12:27:02, 270745 bytes
Driver: C:\WINDOWS\system32\ctdaught.dat, 3/25/2003 12:22:54, 53674 bytes
Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 3/25/2003 12:05:34, 65536 bytes
Driver: C:\WINDOWS\system32\commonfx.dll, 5.12.0001.0381 (English), 3/25/2003 12:19:06, 114688 bytes
Driver: C:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.0382 (English), 4/11/2003 09:50:26, 446464 bytes
Driver: C:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.0382 (English), 4/11/2003 09:52:18, 598016 bytes
Driver: C:\WINDOWS\system32\default.ecw, 9/22/1999 17:18:50, 2259067 bytes
Driver: C:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2001 08:35:46, 36864 bytes
Driver: C:\WINDOWS\system32\ctbas2w.dat, 3/25/2003 12:37:32, 139067 bytes
Driver: C:\WINDOWS\system32\ctsbas2w.dat, 3/25/2003 12:37:30, 250284 bytes
Driver: C:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 06:42:28, 7406 bytes
Driver: C:\WINDOWS\system32\Audigy.bmp, 11/13/2001 03:48:20, 1912 bytes
Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0000.0002 (English), 3/25/2003 11:14:30, 49152 bytes
Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0351 (English), 3/27/2003 04:58:56, 287920 bytes
Name: Realtek RTL8169/8110 Family Gigabit Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8169&SUBSYS_025C1462&REV_10\4&3191A3E6&0&6870
Driver: C:\WINDOWS\system32\DRIVERS\Rtlnicxp.sys, 5.612.0413.2004 (English), 4/13/2004 12:14:12, 70144 bytes
Name: NVIDIA nForce3 250 Serial ATA Controller (v2.6)
Device ID: PCI\VEN_10DE&DEV_00EE&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&48
Driver: C:\WINDOWS\system32\DRIVERS\nvatabus.sys, 5.10.2600.0446 (English), 6/3/2004 10:40:46, 79360 bytes
Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 6/3/2004 02:40:48, 294400 bytes
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_00ED&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/4/2004 06:07:46, 68224 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_00E8&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&12
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/4/2004 06:08:37, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/4/2004 06:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 07:56:46, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/4/2004 06:08:42, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 07:56:42, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_02501462&REV_A1\3&13C0B0C5&0&11
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/4/2004 06:08:36, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_02501462&REV_A1\3&13C0B0C5&0&10
Name: NVIDIA nForce3 250 Parallel ATA Controller (v2.6)
Device ID: PCI\VEN_10DE&DEV_00E5&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&40
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_00E4&SUBSYS_02501462&REV_A1\3&13C0B0C5&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_00E3&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&50
Name: NVIDIA nForce3 250 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_00E2&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&58
Driver: C:\WINDOWS\system32\DRIVERS\nv_agp.SYS, 4.12.0001.0436 (English), 4/2/2004 15:40:00, 21760 bytes
Driver: C:\WINDOWS\system32\NVCOG.DLL, 1.00.0000.0015 (English), 4/2/2004 15:40:00, 32256 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_00E1&SUBSYS_00000000&REV_A1\3&13C0B0C5&0&00
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_00E0&SUBSYS_00000000&REV_A2\3&13C0B0C5&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 21:00:00, 35840 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_00DF&SUBSYS_02501462&REV_A2\3&13C0B0C5&0&28
Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.0482 (English), 4/6/2005 03:22:30, 12928 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0000.0482 (English), 4/6/2005 03:22:12, 261888 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.0482 (English), 4/6/2005 03:22:02, 208256 bytes
Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 4/6/2005 03:19:20, 9728 bytes
Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 4/6/2005 03:19:20, 9728 bytes
Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0017 (English), 4/4/2005 19:00:26, 32256 bytes
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&13C0B0C5&0&C0
Driver: n/a
Name: RADEON 9600 SERIES - Secondary
Device ID: PCI\VEN_1002&DEV_4172&SUBSYS_7C28174B&REV_00\4&1AD7642&0&0158
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6575 (English), 9/15/2005 02:58:28, 1339392 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0005 (English), 9/15/2005 02:03:40, 40960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 9/15/2005 05:46:40, 23968 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 6/8/2005 19:45:54, 58560 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 9/1/2005 16:51:43, 929 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 9/1/2005 16:51:43, 524850 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6575 (English), 9/15/2005 02:58:47, 241664 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0298 (English), 9/15/2005 01:59:20, 233472 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 9/15/2005 02:53:28, 25088 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0347 (English), 9/15/2005 02:44:49, 2429952 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0071 (English), 9/15/2005 02:39:22, 602016 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 9/6/2005 20:04:27, 104373 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0007 (English), 9/15/2005 02:51:47, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 9/15/2005 02:04:27, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 15:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4121 (English), 9/15/2005 02:52:10, 376832 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4121 (English), 9/15/2005 02:53:13, 46080 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2494 (English), 9/15/2005 02:53:45, 106496 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0014 (English), 9/15/2005 02:53:35, 73728 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2499 (English), 9/15/2005 02:53:23, 39936 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0028 (English), 9/15/2005 02:27:18, 147456 bytes
Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.02.2083.43054 (English), 9/15/2005 04:55:11, 253952 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 8/16/2005 20:57:20, 5607 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.5396 (English), 9/15/2005 03:13:08, 4837376 bytes
Driver: C:\WINDOWS\system32\atioglx1.dll, 6.14.0010.1014 (English), 9/15/2005 04:14:50, 6680576 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 9/15/2005 05:32:27, 307200 bytes
Device ID: PCI\VEN_1002&DEV_4152&SUBSYS_7C29174B&REV_00\4&1AD7642&0&0058
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 21:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:41 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:41 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:41 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 21:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:41 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 21:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 21:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 21:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 21:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 21:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 21:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:48 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:48 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:03 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:03 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:48 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 21:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 21:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 21:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:57 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 21:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:44 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 21:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 07:56:42 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 07:56:46 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:41 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:42 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 07:56:42 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:42 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:57 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:43 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 20480 bytes
qasf.dll: 10.00.0000.3646 English Final Retail 9/22/2004 18:46:02 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:24 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/30/2005 03:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 07:56:45 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 07:56:57 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 07:56:57 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 07:56:42 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 07:56:42 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 07:56:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 07:56:42 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 07:56:42 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 07:56:57 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:44 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 06:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/4/2004 05:58:38 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/4/2004 05:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 05:58:41 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 05:58:41 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:57 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 07:56:43 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:57 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:44 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 07:56:46 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.00.0004.0822
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
InterVideo Audio Processor Fx,0x00400000,1,1,Auprocfx.ax,
Vorbis Decoder,0x00600000,1,1,OggDS.dll,0.09.0009.0005
InterVideo Video Decoder,0x00700000,2,4,IVIVIDEO.ax,5.03.0005.0037
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,1.02.0001.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
Matroska Source,0x00600000,0,0,MatroskaSplitter.ax,1.00.0002.0004
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,1.02.0012.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0003.0024
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,1.01.0001.0000
Matroska Splitter,0x00600000,1,1,MatroskaSplitter.ax,1.00.0002.0004
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,1.00.0006.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CT Null Render Filter,0x00200000,1,0,NullRndr.ax,1.00.0001.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.00.0000.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0000.0001
CoreCodec DynEQ,0x00200000,1,1,dyneq.cll,1.00.0002.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0006
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
CoreCodec Audio Source,0x00600000,0,1,ccaudiosource.cll,0.05.0000.1150
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,1.01.0000.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0006
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,1.01.0000.0000
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0000.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
InterVideo Audio Decoder,0x00700000,1,1,iviaudio.ax,5.03.0005.0037
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CoreCodec WPW,0x00200000,1,1,wawrap.cll,8.00.0000.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,1.02.0001.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0006
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Vorbis Encoder,0x00200000,1,1,OggDS.dll,0.09.0009.0005
Ogg Multiplexer,0x00400000,1,1,OggDS.dll,0.09.0009.0005
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
RIFF/CDXA Source,0x00400000,0,1,xcdsrc.ax,8.01.0000.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
InterVideo Navigator,0x00190000,0,3,IVInav.ax,5.03.0005.0037
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Noise Reduction,0x00100000,1,1,NoisRedu.ax,2.00.0000.0001
CoreCodec CDDA Source,0x00600000,0,1,cddasource.cll,0.08.0000.0104
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Decoder,0x00600000,2,1,NeVideo.ax,1.01.0007.0001
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,1.02.0001.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,1.00.0007.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.0933
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CoreCodec Subtitles Dispatcher,0x00200000,1,0,subdispatch.cll,1.00.0000.0003
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0004
NeroDigital Parser,0x00600000,0,3,NDParser.ax,1.00.0001.0027
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,1.02.0008.0000
WMplug,0x009001f4,1,1,wtwmplug.ax,
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ogg Splitter,0x00600000,1,1,OggDS.dll,0.09.0009.0005
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0006
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Geovision MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
GeoVision MPEG2 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V3,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
SB Audigy Audio [9000],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy MIDI Port [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy Sw Synth [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy Synth A [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy Synth B [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
SB Audigy MIDI Port [9000],0x00200000,2,2,,5.03.2600.2180
SB Audigy Audio [9000],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB Audigy DirectMusic Synthesizer [9000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Sw Synth [9000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Synth A [9000],0x00200000,1,1,,5.03.2600.2180
SB Audigy Synth B [9000],0x00200000,1,1,,5.03.2600.2180
Video Capture Sources:
AIPTEK PenCam,0x00200000,0,0,qcap.dll,6.05.2600.2180
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
SB Audigy Audio [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: SB Audigy Audio [9000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
SB Audigy Synth A [9000],0x00200000,11,2,,5.03.2600.2180
SB Audigy Audio [9000],0x00200000,13,2,,5.03.2600.2180
ATI Report
===============================GENERAL=================================
Problem Report Version: 2.15
10/11/2005 -- 00:53:18
C:\Documents and Settings\Chris\Desktop\ATI.TXT
=========================CUSTOMER INFORMATION==========================
Graphics Card S/N:
Machine or Motherboard Brand/Model: Nvidia Nforce3 MB
Company:
Street:
City:
Province/State:
Country:
Postal Code:
Phone Number: *
Fax Number:
E-mail Address: *
==========================PROBLEM INFORMATION==========================
Problem Description: *
Direct3d and Direct Draw options not available
Have Updated the Video Drivers to latest, also the M/B and DirectX is current
versions
Steps to recreate the problem: *
DVD and Direct3d Screensavers not functioning etc
======================DISPLAY ADAPTER INFORMATION======================
Graphics Card Manufacturer = Sapphire Technology Ltd.
Graphics Chipset (ASIC) = RADEON 9600 SERIES
Device ID = 4152
Vendor ID = 1002
Subsystem ID = 7C29
Subsystem Vendor ID = 174B
Bus Type = AGP
Current Bus Settings = AGP 8X
Primary Display Device = Yes
BIOS P/N = 113-PC2902-06
BIOS Version = 0.2063
BIOS Date = 2003/11/14
Memory Size = 256 MB
Memory Type = DDR SGRAM / SDRAM
Tuner Type = Not Detected
Decoder Type = ImpacTV2+
Video Standard = PAL
Audio Type = Not Detected
Display Drivers Version = 8.18-050914a1-027256C-ATI
Display 2D Version = 6.14.10.6575
Display D3D Version = 6.14.10.4071
Open GL Version = 6.14.10.5396
Control Panel Version = 0.0.0.0
Device ID = 4172
Vendor ID = 1002
Subsystem ID = 7C28
Bus Type = PCI
Current Bus Settings = Not Detected
Primary Display Device = No
Decoder Type = Not Detected
Video Standard = Not Detected
========================MOTHERBOARD INFORMATION========================
CPU Type = AMD Athlon(tm) 64 Processor 3500+
CPU Speed = 2210 MHz
North Bridge Chipset Vendor ID = 10de
North Bridge Chipset Device ID = e1
North Bridge Chipset Revision = a1
North Bridge Chipset Drivers Version = 5.1.2600.0
North Bridge Chipset Drivers Date = 7-1-2001
South Bridge Chipset Vendor ID = 10de
South Bridge Chipset Device ID = e2
South Bridge Chipset Revision = a2
South Bridge Chipset Drivers Version = 5.1.2600.0
South Bridge Chipset Drivers Date = 7-1-2001
Presence of Dual CPU = No
System RAM Amount = 2048 MB
======================SYSTEM HARDWARE INFORMATION======================
Device Item Number = 146
Device\DeviceItem0000 = [Processors] -> [AMD Athlon64 Processor]
Device\DeviceItem0001 = [System devices] -> [ACPI Fixed Feature Button]
Device\DeviceItem0002 = [System devices] -> [Programmable interrupt
controller]
Device\DeviceItem0003 = [System devices] -> [System timer]
Device\DeviceItem0004 = [System devices] -> [Direct memory access controller]
Device\DeviceItem0005 = [Ports (COM & LPT)] -> [Printer Port]
Device\DeviceItem0006 = [Ports (COM & LPT)] -> [Communications Port]
Device\DeviceItem0007 = [Floppy disk controllers] -> [Standard floppy disk
controller]
Device\DeviceItem0008 = [System devices] -> [System speaker]
Device\DeviceItem0009 = [System devices] -> [PCI bus]
Device\DeviceItem0010 = [System devices] -> [System CMOS/real time clock]
Device\DeviceItem0011 = [System devices] -> [System board]
Device\DeviceItem0012 = [System devices] -> [Motherboard resources]
Device\DeviceItem0013 = [System devices] -> [Motherboard resources]
Device\DeviceItem0014 = [System devices] -> [Numeric data processor]
Device\DeviceItem0015 = [System devices] -> [ACPI Power Button]
Device\DeviceItem0016 = [System devices] -> [Microsoft ACPI-Compliant System]
Device\DeviceItem0017 = [Bluetooth Radios] -> [Microsoft Bluetooth
Enumerator]
Device\DeviceItem0018 = [Network adapters] -> [Bluetooth Device (Personal
Area Network)]
Device\DeviceItem0019 = [Network adapters] -> [Bluetooth Device (RFCOMM
Protocol TDI)]
Device\DeviceItem0020 = [Ports (COM & LPT)] -> [Standard Serial over
Bluetooth link]
Device\DeviceItem0021 = [Monitors] -> [Dell E771p]
Device\DeviceItem0022 = [Monitors] -> [ SyncMaster 171S/ 175S/ 170S,
SyncMaster Magic CX175S-AZ/LX175S]
Device\DeviceItem0023 = [Floppy disk drives] -> [Floppy disk drive]
Device\DeviceItem0024 = [Mice and other pointing devices] -> [Logitech
HID-compliant Cordless Mouse]
Device\DeviceItem0025 = [Keyboards] -> [HID Keyboard Device]
Device\DeviceItem0026 = [Human Interface Devices] -> [HID-compliant device]
Device\DeviceItem0027 = [Human Interface Devices] -> [HID-compliant consumer
control device]
Device\DeviceItem0028 = [DVD/CD-ROM drives] -> [CD-ROM Drive]
Device\DeviceItem0029 = [DVD/CD-ROM drives] -> [CD-ROM Drive]
Device\DeviceItem0030 = [Disk drives] -> [Disk drive]
Device\DeviceItem0031 = [Disk drives] -> [Disk drive]
Device\DeviceItem0032 = [System devices] -> [ISAPNP Read Data Port]
Device\DeviceItem0033 = [System devices] -> [Printer Port Logical Interface]
Device\DeviceItem0034 = [Display adapters] -> [RADEON 9600 SERIES ]
Device\DeviceItem0035 = [Display adapters] -> [RADEON 9600 SERIES - Secondary
Device\DeviceItem0036 = [System devices] -> [PCI standard host CPU bridge]
Device\DeviceItem0037 = [System devices] -> [PCI standard host CPU bridge]
Device\DeviceItem0038 = [System devices] -> [PCI standard host CPU bridge]
Device\DeviceItem0039 = [System devices] -> [PCI standard host CPU bridge]
Device\DeviceItem0040 = [NVIDIA Network Bus Enumerator] -> [NVIDIA Network
Bus Enumerator]
Device\DeviceItem0041 = [System devices] -> [PCI standard ISA bridge]
Device\DeviceItem0042 = [System devices] -> [PCI standard host CPU bridge]
Device\DeviceItem0043 = [System devices] -> [NVIDIA nForce3 250 AGP Host to
PCI Bridge]
Device\DeviceItem0044 = [IDE ATA/ATAPI controllers] -> [NVIDIA nForce3 250
Serial ATA Controller (v2.6)]
Device\DeviceItem0045 = [System devices] -> [NVIDIA nForce PCI System
Management]
Device\DeviceItem0046 = [IDE ATA/ATAPI controllers] -> [NVIDIA nForce3 250
Parallel ATA Controller (v2.6)]
Device\DeviceItem0047 = [Universal Serial Bus controllers] -> [Standard
OpenHCD USB Host Controller]
Device\DeviceItem0048 = [Universal Serial Bus controllers] -> [Standard
Device\DeviceItem0049 = [Universal Serial Bus controllers] -> [Standard
Enhanced PCI to USB Host Controller]
Device\DeviceItem0050 = [System devices] -> [PCI standard PCI-to-PCI bridge]
Device\DeviceItem0051 = [IDE ATA/ATAPI controllers] -> [NVIDIA nForce3 250
Device\DeviceItem0052 = [Network adapters] -> [Realtek RTL8169/8110 Family
Gigabit Ethernet NIC]
Device\DeviceItem0053 = [Sound, video and game controllers] -> [Creative
Audigy Audio Processor (WDM)]
Device\DeviceItem0054 = [IEEE 1394 Bus host controllers] -> [OHCI Compliant
IEEE 1394 Host Controller]
Device\DeviceItem0055 = [Sound, video and game controllers] -> [Creative Game
Port]
Device\DeviceItem0056 = [IEEE 1394 Bus host controllers] -> [VIA OHCI
Compliant IEEE 1394 Host Controller]
Device\DeviceItem0057 = [Network adapters] -> [Sitecom Wireless Network PCI
Adapter 54G WL-115]
Device\DeviceItem0058 = [Computer] -> [ACPI Uniprocessor PC]
Device\DeviceItem0059 = [System devices] -> [Logical Disk Manager]
Device\DeviceItem0060 = [System devices] -> [Volume Manager]
Device\DeviceItem0061 = [Non-Plug and Play Drivers] -> [AFD Networking
Support Environment]
Device\DeviceItem0062 = [Non-Plug and Play Drivers] -> [1394 ARP Client
Protocol]
Device\DeviceItem0063 = [Non-Plug and Play Drivers] -> [Standard IDE/ESDI
Hard Disk Controller]
Device\DeviceItem0064 = [Non-Plug and Play Drivers] -> [Beep]
Device\DeviceItem0065 = [Non-Plug and Play Drivers] -> [Cft Clifford Wizard
Driver]
Device\DeviceItem0066 = [Non-Plug and Play Drivers] -> [Creative AC3 Software
Decoder]
Device\DeviceItem0067 = [Non-Plug and Play Drivers] -> [Creative DVD-Audio
Device Driver]
Device\DeviceItem0068 = [Non-Plug and Play Drivers] -> [Creative Proxy
Driver]
Device\DeviceItem0069 = [Non-Plug and Play Drivers] -> [Creative SoundFont
Management Device Driver]
Device\DeviceItem0070 = [Non-Plug and Play Drivers] -> [dmboot]
Device\DeviceItem0071 = [Non-Plug and Play Drivers] -> [dmload]
Device\DeviceItem0072 = [Non-Plug and Play Drivers] -> [E-mu Plug-in
Architecture Driver]
Device\DeviceItem0073 = [Non-Plug and Play Drivers] -> [EntDrv51]
Device\DeviceItem0074 = [Non-Plug and Play Drivers] -> [Fips]
Device\DeviceItem0075 = [Non-Plug and Play Drivers] -> [GMSIPCI]
Device\DeviceItem0076 = [Non-Plug and Play Drivers] -> [Generic Packet
Classifier]
Device\DeviceItem0077 = [Non-Plug and Play Drivers] -> [Creative Hardware
Abstract Layer Driver]
Device\DeviceItem0078 = [Non-Plug and Play Drivers] -> [Creative P16V HAL
Driver]
Device\DeviceItem0079 = [Non-Plug and Play Drivers] -> [HTTP]
Device\DeviceItem0080 = [Non-Plug and Play Drivers] -> [IO.DLL Driver]
Device\DeviceItem0081 = [Non-Plug and Play Drivers] -> [IP Network Address
Translator]
Device\DeviceItem0082 = [Non-Plug and Play Drivers] -> [IPSEC driver]
Device\DeviceItem0083 = [Non-Plug and Play Drivers] -> [ksecdd]
Device\DeviceItem0084 = [Non-Plug and Play Drivers] -> [AEGIS Protocol (IEEE
802.1x) v2.3.1.9]
Device\DeviceItem0085 = [Non-Plug and Play Drivers] -> [mnmdd]
Device\DeviceItem0086 = [Non-Plug and Play Drivers] -> [mountmgr]
Device\DeviceItem0087 = [Non-Plug and Play Drivers] -> [NaiAvFilter1]
Device\DeviceItem0088 = [Non-Plug and Play Drivers] -> [NaiAvTdi1]
Device\DeviceItem0089 = [Non-Plug and P
LOL
yea i know its long but i thought if i didnt include all the information i could then someone will ask for it
I have tried reinstalling directx aswell
The Quest goes on....
