my sister-in-law as a new Dell computer, Windows ME,that has a Dell Gefore2MX (32mb) video card. they have been having problems with the computer when playing games. so I started by checking the hardware to make sure that everthing was installed, it was. so I started with DirectX, they had Directx8 installed (know this using the Directx Diagnostic tool), but there DirecDraw Acceleration was Disabled, Direct3d Acceleration was Disabled, and AGP Texture Acceleration was Disabled. I did not think that was ok, so to get them enabled I used the 'test' buttons to the right of the options. Test DirectDraw work, and I was able to enable it. Test Direct3d failed, and the enable button have since been grayed out (do not function). the AGP texture acceleration enable button is grayed out, and its test button are grayed out. Ok, so I figured that the video drivers were not working (too old for Directx8). so I downloaded the latest Nvidia drivers, installed them, they work good. I go back into the Directx Diag tool, and try the 'test direct3d'.. it passes. great, but the enable button is still grayed out, cant be set, why??
I downloaded Directx8a, and installed that. but it does the same as above..
any one have any suggestions on how to get the Direct3d Acceleation and AGP texture Acceleration Enabled????
