Franz316
I think I made a big mistake, this problem was created by me and now I can't fix it. I wanted to go back to 8.0a because my system seemed to run better with it. So I used DirectXBuster and uninstalled version 8.1. It went fine and I had no DirectX on my computer. 8.0 wouldn't install so I decided to go back to 8.1. I downloaded the Win2k one and installed it. The installation says it installed fine but when I run DXdiag it says all the files are missing. The weird thing is that when I play Medal of Honor it works fine. But when I play Freedom Force it says it need 8.1. Can anyone explain to me the best way to reinstall it?
-Thanks alot
-Thanks alot
