Direct X 8 artifacts in D3D please help!!! dont wanna reformat =(
tornado666
23
I have a pentium3 700 at 933 and hercules gts 64meg abit mobo etc
Anyway, my computer works great with dx7 and any multitude of drivers...if i upgrade to dx8.. open gl apps work fine but anything direct 3d and I get weird flashing horizontal lines accross the screen that look like weird extensions of textures or something.. I have tried uninstalling/reinstalling dx7 and dx8 a bunch of times... wierd thing is.. sometimes i can get dx8 loaded and i wont have the problem.. but if i try to change drivers NO MATTER what drivers they are.. it comes back.. but if i completely clean out dx8 and go back to dx7 it goes away....The way this problem is acting I am almost wondering if a reformat would even work... it almost seems like just some kind of hardware incompatibility but i could be wrong...I guess i'll try the new dx8 beta when i get home... Reformatting is my last option cuz that is inconvenient as hell
any help would be greatly appreciated
thanks
vohwink1
174
what drivers are you using for your vid card? Newest? I'd recomend the 12.41's or the 12.60 which I'm using perfectly fine right now, much better performance than with the old drivers.
