I was thinking about making a cheapo copper cap and bar stock type water block, but I was wondering about this,
What if instead of using a block simply flushed cool liquid directly onto the cpu core(were the outlet of the pipe would be a couple of centameters from the chip itself)? I wouldn't use water, but a dielectic oil such as pure mineral oil which is electricly inert so I wouldn't have to worry about frying anything out.. I've seen this thing done on older cpu's were the ceramic part was as big as the base of it, and I seen it once done on a early athlon (I think it was) were the guy covered the capaciters on the chip with epoxy and water cooled it. It cooled it to 32 degrees were a high-performance heat sink only cooled it to 40 something.
would cool oil being sprayed directly on the small chip be enough to disipate the heat or a overclocked XP proccessor? Even though oil is a much more efficient transferer of heat then air would this be enough to suck the heat from a tiny surface area?
Another thing, would a water pump be able to handle thin oil without burning out?
