dip switch settings on an epox 8K7A
The Mudman
168
I'm in the process of putting this new box together and I run into a small question. My question is do I set the CPU ratio selection to 10* for an athlon 1 gig. I just need a little assurance here.
Thanks
Comguy12
32
Depends on your processor. There are two versions. The 1.0GHz 200, and the 1.0GHz 266. The second number refers to the Front Side Bus (Double Data Rate). I would start with a 7.5 multiplier and a 133 MHz front side bus. This will give better performance than a 100 MHz bus.
You might also want to check into closing the L1 bridges. You can do a search on how to do that. It is easy, and will unlock the factory settings on your chip.
The Mudman
168
thanks for the reply Comguy. I've got a 266 fsb processor. I just read that I could leave the Cpu ratio switch to Auto and bios would take care of everything. Is this A good idea or should I set the switches to 7.5 ??
